Spaceball5000 USB & SWX2011-64 bit
Hi guys.
We just upgraded to SWX2011-64 bit from SWX2010-64 bit
and I lost my buttons on spaceball 5000 usb. When I try to re-map any button, the pull-down list is empty...
We are running Windows XP-64 and it worked fine up until Solidworks 2011 got installed.
Has anyone experienced this and found a solution by any chance?
Most of our designers use space explorer and I prefer to use the old style, since I find button layout on the old ones to be a lot better. And it is a lot better ergonomically.
Any thoughts?
Thanks.
Eddie
Any thoughts?
Thanks.
Eddie
RE: Spaceball5000 USB & SWX2011-64 bit
Sorry not what you want to hear.....
Anna Wood
Xeon W3680, Nvidia Quadro 4000, 12 Gb RAM, WD Velociraptor, Dell U3011 Monitor
SW2011 SP1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
I re-installed the driver (version 3.6.11) and it works. Must have been some glitch...
Thank you for response, anyway.
Eddie
I know I have a several serial spaceballs that are now paperweights.
Anna Wood
5000 is a USB model and works with Windows XP 64-bit and Solidworks 20xx-64 bit versions using older drivers.
I wish 3Dconnexion would support the style I have for a bit longer. I'm not at all impressed with their newer products.
I've been using a Pro since they came out and I love it.
Kinda have a few connections with them, wrote an article for them.
If first you do succeed...try something harder.
Blair H.
SW 2009 sp3.0, HP x4600
3.16ghz Intel Core2 Duo,
3.0 GB ram,
Nvidia Quadro FX 1700
Space Pilot Pro...they ROCK!!
3D connexion doesn't support 5000 anymore.
You can only use it under Windows XP (32 and 64 bit)
and 4000FLX (or 5000 serial) would only work with Windows XP 32-bit...
There is no work around this.
The driver I use is 3.6.11 which is quite old.
CADShark:
I find button sizes and locations the most conveniently placed for me on the Spaceball 5000. Layout of the Pilot is not much different from Space explorer. I don't mind using the puck instead of the ball - the buttons is what I don't like.
Dell Precision 690, NVidia Quadro FX 3500 Graphics Card 256 MB, Intel Xeon, CPU 3.00 Ghz, Dual Processors, 4 GB ram, Spaceball 5000 USB
