Opening 2011 files with 2010 Version
I am using 2010 version of solid works. In attempting to open an assembly from a co-worker using 2011 version I am unable to open.
The error message says I cannot open because of a "future version". Is there a way around this? Thanks in advance
RE: Opening 2011 files with 2010 Version
SW is not backwards compatiable, so your best solution is for either your Coworker to not move to the latest version or you need to move up to SW2011. But neither of you can work in different MAJOR versions. You can work in different Service packs, in the same COMMON MAJOR version.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
Dan
www.eltronresearch.com
Dan's Blog
