how to fix scratched panel surface painting?
Hello All,
There are some electrical panel surfaces been scratched during construction as shown attaced. Is there any method to recover the panel surface? Thank you.
http:// files.engi neering.co m/getfile. aspx?folde r=a0a77c6e -e833-4b4f -b222-b7f7 88e0311c&a mp;file=IM G_6225.JPG
http:// files.engi neering.co m/getfile. aspx?folde r=df14f75b -af15-4e03 -81e8-7835 2faf1d8d&a mp;file=IM G_6222.JPG
http://
http://
RE: how to fix scratched panel surface painting?
Assuming this is in a building (as opposed to an aircraft or spacecraft), then wouldn't one just use a power sander to smooth out the rough edges, mask it off, a couple coats of primer (or perhaps filler), some sanding, and then a finish cost?
With skill and the right paint match, the repair could be made invisible.
On the other hand, if this is on a ship, then you could slather some paint on with a broom...
The metal also has some rust spots on the general dark grey colour of the metal - is it supposed to be zinc coated? If it is zinc coated you need a special primer to be applied first: this may be why your top coat paint has come of in large patches.
