export tool to library
Have just moved to new employer and have to set up NX6 on laptop, this was Ok but I have a problem where I cant export a tool to library. Just getting error message "UNABLE TO UPDATE FILE".
The idea is to enable me to export a tool with the same name as s too part file which contains the model of the said tool.
Any advice would be much appreciated
Currently using NX6
RE: export tool to library
Make sure the Library files are not set to Read Only
I would recommend copying the resource folder in case bad things happen.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
Hi John
Thanks for response.
Changed directory status of Library from Read only and restarted NX but still getting same error message.
Dennis
Currently using NX6
i can export a tool after creating from dropdown menu and also can export a tool retrieved from library. it wont allow me to export a tool if I edit it, for instance tried to create boring bar so selected ID CNMG then changed it to a round insert, once Ive changed it it will not export
Currently using NX6
Ignore previou post still cant export any tool
Currently using NX6
