Shear in Slab with Concentrated Load
I have a situation where a two way slab supported by walls along each side is subject to a 16 kip vehicle load. When this load is close to the edge of the slab there is a high shear stress at the face of the support. Does the code address the width of the slab cross section that should be considered to resist shear? If I assume a 12-inch wide cross section I get a 20-inch thick slab. 18-inch wide cross section I get a 14-inch thick slab, 24-inch wide cross section I get a 12-inch thick slab.
RE: Shear in Slab with Concentrated Load
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
I am checking the beam shear at the support wall.
Looking at it like a simply supported beam with a large concentrated load near the face of the support, would you not need to check the beam shear?
My question is what to assume for bw in 2XSQRT(f'c)XbwXd??
"I would spread it out at a 45 degree line each side and check the shear on that width."
This is basically what I have done in the past. I was hoping someone could point me in the direction of a code requirement that backs it up.
ATSE,
I would not think the entire width of the wall could be considered. It would seem that the shear in the slab would be equal to the reaction that the slab is putting on the wall which would be much higher at the location of the load than 5 feet away.
See the attached file for calculating slab width for concentrated load.
Check AASHTO design criteria. This is similar to a bridge slab near the supports. I believe the early criteria were 24"+some percentage of the span.
