Stiffener Spacing
Stiffener Spacing
Stiffener Spacing
I am analyzing girders that have web stiffeners staggered on opposite sides of the girder. On each side the space is 7'-0 but they are staggered 3'-6".
What would you consider the spacing to be?
7'-0?
3'-6?
somewhere in between?
RE: Stiffener Spacing
I would use 3'-6...assuming the stiffeners were designed as single stiffeners.
I think it depends on the loading and how that relates to the stiffener locations. These are stiffeners for flange bracing due to point loads?
For resistance to web buckling or crippling, I'd go with the 3'-6" per SAIL3...assuming that the stiffeners meet the design specification.
JAE-
The spec is AISC.
Problem is, I am using AIST 13 for mill buildings, which basically requires that the stiffeners are used in pairs.
You say "For resistance to web buckling or crippling" and I guess they are. I am assuming they are there for shear capacity.
JAE-
Excuse my ignorance....I have honestly never designed a single stiffener. I just looked in the Spec and found the design for single stiffeners.
I'll check if the stiffeners meet the single stiffener requirement.
RE:'You say "For resistance to web buckling or crippling" and I guess they are. I am assuming they are there for shear capacity.'
For a plate girder these pretty much amount to the same thing, the only difference is the source of the loads.
CSD...after re-reading that, I don't even know what I was thinking when I typed it.
