Man-Camp Waste Water Design
Has anybody had experience designing on-site septic for mining/oil man-camps with about 200 people in the Dakotas. One issue is there is no receiving stream, as the area drains to a local depression/wetland. I'm trying figure out what is typically done in this area. Obviously, a leach field or mound system would be to large because of the GPD loading.
Thanks!
Thanks!
RE: Man-Camp Waste Water Design
I'm not sure of your regulations out there, but from the sound of it, subsurface discharge is the only method with your situation. Therefore, two thoughts:
- can you use multiple mounds or leach fields for your situation? You can design your pump station dosing volume accordingly and discharge it a specific mound.
- can you use alternative designs such as infiltrator systems or eljen to reduce your absorption area?
http://www
http://ww
http://www
htt
The design flows are probably 250 gpd per person. I was thinking about designing a Stablization Pond.
Maybe I have a misunderstanding of what a man-camp is... but 250 gpd seems awfully excessive.
What do they do at this man-camp? Is it a hotel like system or individual sites, similar to a campground?
http://ossf.tamu.edu/evapotranspiration_beds.html
