GAS Threads
GAS Threads
GAS Threads
I need to make a BSP external thread.
I add this at the end of the thd_metric.dat under C:\Programmi\UGS\NX 7.0\UGII, but I don't see this thread.
GAS,0
# Filettature gas compilate da tabella  UNI 339-66 4ed. con lunghezza standard BIMAL
#   Name         Major         Minor    Pitch    Tap Drill    Shaft     Depth
#                 Dia.          Dia.               Dia.        Dia.
#              (internal   (external           (75% full
#               threads)    threads)            thread)
#                 (mm)        (mm)     (mm)      (mm)       (mm)       (mm)
1/8-GAS           9.728      8.566   0.907      8.700       9.600     11.000
1/4-GAS           13.157     11.445   1.337     12.000      13.000     12.000
3/8-GAS           16.662     14.950   1.337     15.500      16.400     14.000
1/2-GAS           20.995     18.631   1.814     19.000      20.700     16.000
3/4-GAS           26.441     24.117   1.814     24.500      26.100     17.000
1-GAS             33.249     30.291   2.309     30.500      33.000     21.000
1_1/4-GAS         41.910     38.952   2.309     39.500      41.600     23.000
1_1/2-GAS         47.803     44.845   2.309     45.000      47.500     25.000
2-GAS             59.614     56.656   2.309     57.000      59.000     26.000
2_1/2-GAS         75.184     72.226   2.309     72.500      75.000     30.000
3-GAS             87.884     84.926   2.309     85.000      88.000     35.000
3_1/2-GAS         100.330    97.372   2.309     97.500      100.500    40.000
4-GAS             113.030    110.072  2.309     110.500     113.500    44.000
5-GAS             138.430    135.472  2.309     135.500     138.500    52.000
6-GAS             163.830    160.872  2.309     161.000     164.000    58.000
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: GAS Threads
First, are these 'tapered' threads?  If so, you have to indicate that by using the name 'GAS,1'.  As for getting them to appear in the list of available Symbolic Treads, you need to go to...
Customer Defaults -> Modeling -> Feature Settings -> Symbolic Threads
...and add 'GAS' to the list of threads in the section of the dialog titled 'Form'.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: GAS Threads
Thank you John.
Thank you...
