spring linearity?
spring linearity?
spring linearity?
I am wondering how linear a real helical compression spring is? Assuming the ends are ground flat, there is some preload, and the coils are not touching, how constant will be the spring rate? Are we talking less than 0.5%? Less than 1%? Less than 5%?
RE: spring linearity?
Why do springs get fatter as they compress? Something to do with Poisson's ratio?
