Calculating Superheat
I am replacing the control system on an industrial ammonia refrigeration system.  The old system displayed a "superheat" value in degrees K.  I don't have access to the code that calculated this superheat value.  I have looked at the T/P charts, but I am still not sure what to calculate for displaying this value.  Any suggestions greatly appreciated!!  RB
RE: Calculating Superheat
You will need a pressure sensor and a temperature sensor at the same point.
From the pressure reading look up the corresponding saturated temperature from your pressure vs. temperature chart.
Actual temperature - saturated temperature = superheat.
Thanks MintJulep...I have pressure and temperature sensors at the suction and discharge.  Which pair should I use?  Thanks again!!  RB
I'd guess suction, but that's really going to depend on what the value is being used for.
Thanks again!!
