Section VIII Failure Theory Basis
In preevious versions of the Code the allowable stress intensity values were based on Tresca (Max Shear Stress) Failure theory. I see the latest version of Div 2 has been converted to Von Mises (max strain energy) failure theory.
Is Div 1 still based on Tresca, or have the allowable values for Div 1 also been "converted" to Von Mises?
Thanks!
Thanks!
RE: Section VIII Failure Theory Basis
"Section I and Division 1 of Section VIII use the maximum stress theory, by implication, but Section III and Division 2 use the maximum shear theory."
Obviously, Div. 2 has changed to Mises (Section III has not). As far as I know only Sec. VIII, Div. 2 got a major overhaul.
At any rate, thanks for the correction, I am now back on track.
