Structural Engineering Library suggestions
All,
I'm in the process of comparing some books from my own personal library to that of my colleagues in the workplace and quite frankly, I'm finding several of my books somewhat lacking.
I was hoping you could recommend/comment on book suggestions listed below?
Steel Design - I have the 4th Edition of McCormacs book, not a bad introductory text but I'm looking to get into a little bit more meat. I heard Salmon and Johnson is good?
Masonry - Multiple people have recommended the Reinforced Masonry Engineering handbook (I currently do not own a masonry book, only the code).
Reinforced concrete - I have a packet of notes put together from my college instructor that is actually quite good. It leaves out a fair amount as I received it in an undergraduate course although I've been told to look into Nawy's book for more in-depth material?
Wood - I have Breyers book and it has served me well.
Mechanics - I have Hibbelers book and Boresi and Schmidts advanced text.
Analysis - I have Leet and Uang's book
Foundations - I could really use a good text in this area, I haven't had a chance to do much foundation design in my career up to this point and what I have done has been fairly simple spread foundations and wall foundations.
Anything other suggestions for books you found particularly useful would be appreciated as well!
RE: Structural Engineering Library suggestions
I think with concrete, you'll likely get a wider range of opinions as far as what is the best. I used McCormac and have no complaints.
Breyer is the way to go with wood, so you're set there.
Masonry- I'd like some opinions on this as well.
Mechanics- I used Gere and it is very good at explaining fundamentals.
Analysis- I like Hibbeler. Like Gere, very good with fundamentals.
I've used Salmon & Johnson and found it to be good.
Mechanics - I like J.P. Den Hartog's "Advanced Strength of Materials". The price is right (Dover paperback). The content (as it claims) is somewhere between a standard strength of materials book and the Timoshenko books (theory of elasticity, plates and shells, & elastic stability).
Just saw one used in a local book store last week, so they are out there.
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
"How To Say It" by Maggio, "...my own personal..." would not have gone over well with several of my high school English teachers.
On the technical side, I find books on applied theory to be more practical.
"Engineering for Steel Construction" by AISC
"PCA Notes for ACI-318"
"Design of Welded Structures" by Blodgett
You can find many good books free in PDF version from FHWA on a variety of topics, primarily geotechnical & foundations. The same goes for the Navy & Army Corps of Engineers.
That's my own personal opinion.
I recently posted the same question about steel design- the resounding response was S and J. A previous employer had that older version and it was very thorough.
Echo Armheim. Breyers is the only wood text I have ever needed, kept it since I graduated in 98. That and the wood manuals have gotten very thorough.
Even if you only do light reinforced concrete, you may find the CRSI manual very valuable, its loaded full of tables and examples and quickly can pay for itself.
Mike McCann
MMC Engineering
Motto: KISS
BA
Foundations - Bowles and Das
Steel - S & J, Blodgett, Geschwindner's Unified Design
Concrete - MacGregor, and PCA Notes on ACI 318
Wood - Breyer
Masonry - NONE. I've never found a good text, just some good examples.
Analysis - Hibbeler
Mechanics - Hibbeler, and Timoshenko
Miscellaneous - Roark, Timoshenko (plates and shells, and theory of elastic stability)
I think that covers everything on my shelf. Well, of course all of the material standards are there - ACI 318, AISC 360-05, NDS, ACI 530 - and codes - ASCE 7, and IBC.
1) Salmon and Johnson's steel book. My is a bit out dated. But, it is still an awesome reference for advanced steel behavior. When you want to understand how steel actually behaves and why the code is written the way it is, then S&J is the book.
2) AISC Design Guides. These are usually very good and very practical. They've got one that goes into great detail about one particular subject (torsion, bolted end plates, welded connections, bolted connections, Floor Vibrations, Column stiffening for moment connections).
3) Analysis: I've purchased a number of analysis books over the years, but most of them are a bit too "academic" for me. I don't need to know too much about higher order shear deformable plate theory. The book I love, which covers some advanced topics in a very accessible way, is "Matrix Structural Analysi" by McGuire, Gallagher and Ziemian.
4) Wood = Breyer. It's practically the bible of wood design.
5) Masonry = "Design of Reinforced Masonry Structures" by Taly. I don't like the format of the book all that much as it can be hard to find what you need. But, it is a good book. I really like RMEH... it's just a little too dated now.
6) Foundations. The Das books are excellent. The Bowles book is too. I also like a lesser known book on retaining walls by Hugh Brooks. I think it is given away when you buy the RetainPro program. But, it is by far the most practical and complete treatment of retaining walls tht I've seen. And, it's written by an SE rather than a PhD.... that's always a + in my view. :)
5) Seismic: I really like the Seismic Design Handbook edited by Farzad Naeim (sp?). It covers a wide variety of topics, but is very well written an relatively easy to follow. The only drawback is that it is a bit dated now.
6) I don't think there are any really great books on concrete. Though the PCA Notes is probably a good reverence to have.
7) Dynamics: I like Mario Paz's book. But, for Response spectra analysis the Gupta book "Response Spectrum Method" is probably the best.
8) Roark's Formulas for Stress and Strain ends up being pretty useful every now and then.
Timeshenko & Gere's Mechanics books are great.
Blodgett's "Design of Welded Structures might be the best book ever printed in the history of mankind in terms of bang-for-the-buck.
I believe this book only costs $22.
It covers far, far more than welding....
No better half anymore. Just the kids. I have several notebooks from school that I keep, too - Advanced Mechanics, Advanced Analysis I & II, Prestressed Concrete, and Advanced Concrete. A Dietrich Metal Stud Binder, PCI Design Handbook, I'm sure there are some others, but right now they're split between home and the office.
When did Lincoln Electric start offering that book again? It was unavailable through them when I got it around 4 years ago. I paid like $60 on Half.com.
Other interesting books:
Guide to Stability Design Criteria for Metal Structures, 5th Edition
Galambos
Cold-Formed Steel Design
Wei-Wen Yu
EIT
Both books will be hard to find though.
The 6th edition of the Reinforced Masonry Engineering Handbook is available from the Masonry Institute of America and it is excellent. It is written around IBC 2006 and ACI 530-05 so it is not too dated. It covers both ASD and LRFD in its examples.
For structural steel design, Salmon and Johnson is the best up-to-date choice. For a slightly dated but advanced text, I recommend "Design of Steel Structures" by Gaylord, Gaylord, and Stallmeyer (3rd edition).
Hokie93
Structural Stability of Steel - Galambos
Theory of Elasticity - Timoshenko
Julius Blum Railing Catalog - this only gets used if I need a reduction factor to get a railing or anchorage to work
You seem to like the Basics of Retaining Walls" Book - Does it give any good examples on Soldier Pile walls (hand calcs). It seems like a short book, but your saying it is pretty good? I have thought a couple of times about buying it, but I thought it would just be filled with pretty pictures.
EIT
Or the use/design of Deadman?
EIT
"Design of Shallow Foundations", ASCE Press, 1999, Samuel E. French
Chapter 11 asks for a "Kings X" on expansive soils, which aren't going away, but I like it very much anyway.
"Pile Construction Design and Practice", Taylor & Francis, 2010, Tomlinson and Woodward, is in metric units, but it's must-have.
Some one of various books by Lymon C. Reese is indispensable for lateral loads on piles and drilled shafts.
It is a fairly short book and the subject matter isn't really all that complex. But, it discussed the topics in a way that was a little more approachable for an SE rather than a Geotech. At the time, I hand't really worked on retaining walls much. It was definitely more helpful and practical than any of the Das or Bowles books that I had.
That being said, I do not remember soldier piles or dead men specifically. Though I think it may have had some discussion of tie backs.
Roark's text WAS the one and only, but once you open Pilkey's, "Formulas for Stress, Strain and Structural Matrices" you'll never touch your Roark's again. Roark's book leaned toward the mechanical engring side, but Pilkey's text is straight up structural.
Blodgett's "Design of Welded Structures" has been rightly praised quite a few times here, though I often end up in his "Design of Weldments" book as well. (Warning: The two books overlap each other here and there...)
Budynas "Advanced Strength and Applied Stress Analysis" for mechanics.
Neville "Properties of Concrete". Regardless of whether you want to be or not, people will often expect you to be a concrete material scientist...
Mike McCann
MMC Engineering
Motto: KISS
Second, I've made three purchases so far based on you folks suggestions and I intend to make a few more after I free up some $$$ from the SO. I've sent off for copies of Salmon and Johnson, Design of Welded Structures and the 6th edition of Reinforced Masonry Engineering Handbook.
Thanks again for all the responses everyone.
I also like Braja M. Das for Retaining Walls/Soils.
Does anyone have suggestions for metal stud framing? It seems we're doing more and more work with that and I'd love some suggestions.
I can't say for sure as I don't own the book but I'm sure this book would be helpful:
Wei-Wen Yu
EIT
Does anyone have a recommendation for seismic and wind lateral load analysis? Ideally the examples would be based on current code (ASCE 7-2005+)
The one I hae goes up through the 2003 IBC, but there might be a newer one.
