NX6 - EXPRESSION MANAGEMENT IN DRAFTING
Most of the time, the "EXPRESSION" in Drafting environment turn to pasive(neutral); I can not modify the dimensions in the views in which I used FEATURE PARAMETERS for adding sketch dimension.
Is there any way to correct that?
RE: NX6 - EXPRESSION MANAGEMENT IN DRAFTING
UGII_DRAFT_EXPRESSIONS_OK=1
Note that starting with NX 7.5, this is now controlled by an option set in Customer Defaults at...
Customer Defaults -> Drafting -> General -> Drawing
...and at the bottom of the page you will find the 'Allow Expressions' option that when toggled ON, the Expression dialog will be active while working in the context of a Drawing.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
Tomas
John R. Baker, P.E.
Industry Sector
Cypress, CA
