problem with Tranlational Joint Motion
Hallo,
I am using Adams/View. I want to simulate two translational moves in my model in 60 seconds space, by using only one "Tranlational Joint Motion". How to do it? Rigt now, I can generate only one motion using function STEP. I simply want to eject and return the hydraulic cylinder. Can anyone help me?
RE: problem with Tranlational Joint Motion
Thank you for help, but it didn't work. The mechanism has locked up.
Have you got any other ideas?
Well, I've found the solution:
STEP(TIME,1,0,2,1)+STEP(TIME,2,0,3,-1)
Any other combination didn't work. Anyway, thanks for trying to help :)
