show crosshairs even if not dimensioning to them?
For example, I have a top view where I dimension the location of a thru hole. That view has crosshairs
Two projection views later I have a bottom view. I can now see the other end of the thru hole, but I am not dimensioning to it (to prevent overconstraint).
Is it correct to show the crosshairs on the bottom view as well? I feel it would just clutter up my drawing.
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/_chrisloughnane
RE: show crosshairs even if not dimensioning to them?
To take your example to an extreme - we have assemblies with hundreds of holes in them. We omit center lines in these instances unless we are dimensioning to the axes. If we did not omit the center lines, the drawing would look like a spider's web.
I would let clarity dictate the use of center lines.
Either way, I don't add centermarks unless there is a dimension to the hole because this makes it clear that there is no dim to that hole (missing or otherwise). They can also clutter the drawing if over used.
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
Powerhound, GDTP T-0419
Engineering Technician
Inventor 2010
Mastercam X5
Smartcam 11.1
SSG, U.S. Army
Taji, Iraq OIF II
I basically inconsistently add them when I feel it adds clarity/improves the drawing.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
