Measuring draft
Measuring draft
Measuring draft
What is the equal in mm to draft angle,   1 degree = ? mm
RE: Measuring draft
An angle is an angle. The degree of an angle is the same in inches as it is in a meric drawing. The only way you can put a measurable dimension on an angle is at some measurable distance form a base point/plane.
Ben Loosli
RE: Measuring draft
Yeah, i have that same feeling.
RE: Measuring draft
RE: Measuring draft
Perhaps someone was trying to figure out an angle based on some measurements and eh?-squared plus be-square equals see-double-squared.
Peter Truitt
Minnesota
RE: Measuring draft
I have seen a 1 degree taper called up as .017mm/1mm on some old polystyrene casting designs, but not for a long time.
I would suspect this is a modern twist on go get some metric sine tables, I only have imperial ones.
