Seal question (Viton oring on metal surface)
Hi all, great forum you all have here, I'm hoping to get some advice.
Basic issue is this.
I'm trying to come up with a solution to an ongoing problem with what I'll describe as (oily liquid) from penetrating underneath the seal and damaging the internal electronic components of an assembly.
I believe the major contributor of the the failure is that the metal sealing surface finish is not the correct finish to create a proper seal for the oring. The finish for lack of better terms looks like random micro scratches going in every direction.
The oring is rectangular in shape. I would like to suggest a micro finish that would create a good seal. What type of finish would you suggest and about how many microns/milimeters would you suggest the finish be. The oring size is 3.5mm diameter.
Thanks in advance for any suggestion/advice. Sorry is this seems a bit vague here.
J.G.
J.G.
RE: Seal question (Viton oring on metal surface)
You don't say if it is a static or dynamic seal. That will make a big difference in the recommended squeeze. Parker, Minnesota Rubber & many other suppliers have design guides with everything you need.
I'll try to answer your questions.
Flexibox, the other major problem is that there is currently no groove or channel for the o-ring in the metal flange. The groove is currently on the bottom of the plastic molded heaters. So basically the o-ring lays into the bottom of the plastic molded heaters which then lays on top of bare metal, metal that is not finished correctly. I believe it should be reversed. O-ring grove in the metal flange plate, with no groove on the bottom of the heater assembly.
Dgallup, thanks for the advice on Ra. currently I have no idea what the surface Ra is. I really need to take this part into a good machine shop to get a good gauge on what I'm dealing with. From what I'm used to in my previous line of work (semiconductor) the sealing surface and overall design is terrible.
The seal is static, there is no movement between the parts. Basically it's several small plastic heater assemblies, rectangular in shape that screw down onto the metal flange. We need a good seal to keep out Aliphatic oil fluid that is sprayed down onto the individual heaters.
Dlite, thanks. I agree trying to use a standard circular o-ring versus a custom square gasket/o-ring would be best. However since there is currently no deep o-ring groove in the metal this would be difficult to work with. I think that the groove on the bottom of the plastic molded heaters is not deep enough to work with a standard circular o-ring.
Btrueblood, actually looking back the o-ring is nitrile.
The temperature of the heater itself reaches ~90C / 194F. However the seal does not see that temperature. The heating element is elevated about 1/2" above the o-ring, separated by the plastic heater body.
As for the oily liquid that's used. All I know is that it's an Aliphatic oil, kinda the same consistency and color as extra light olive oil . This oil gives us issues in another application in the use of plastic inline filters with o-ring as it tends to just slowly seep around the seal.
I'd love to show drawing and pics here but the company wouldn't like it much if they found out. Thanks for the advice!!!
