Boiler Tube Plugs
Boiler Tube Plugs
Boiler Tube Plugs
I keep getting conflicting information regarding acceptable material for boiler tube plugs.  I find SA-36 plugs readily available, but some have said that plugs must be made of SA-105 and not SA-36.  Anyone else being told this?
RE: Boiler Tube Plugs
The material for boiler tube plugs can be any material that is permitted by Section I in Section II, Part D, Table 1A.
i have had good luck with these:
Consider expansion plugs (Torque'n seal) for your application. They have been around for a long time
http://www.tubeplug.com/highpressuretubeplugs.shtml
These wrench-actuated plugs work well in tight places where hammer driven plugs may not work.
They do, of course, cost a bit more.
Are you maintaining a tubesheet "plugging map" ?  These become invaluable when evaluating the HX for future retube/replace decisions.
tell us more about the HX......
MJC,
You have plugged boilers with Torq-N-seals?
rmw
is it for a firetube or watube boiler?
I am referring to plugging tubes in watertube boilers, don't think I've seen anyone plug any tubes in firetube boilers.
Metengr....if using SA-s6 then one should perform a thickness calculation?  Taperred plug could then be machined to assure at least the calculated thickness is driven into the tube or tubehole.
Pre-designed tapered plugs can be used directly provided the correct material is selected. There should be no need for calcs.
