saltwater proof potting compound
3
Hi all,
I'm looking for a potting compound that will withstand saltwater immersion. Can anyone recommend a manufacturer? or can I just go with Digi-key's off the shelf material?
RE: saltwater proof potting compound
You may also want to look at silicone's from people like Nusil or
3m.  Silicone is used on a lot of underwater equipment.   Dymax offers a some good UV cured materials.  Depending on your configuration you maybe able to use a Marine Caulk like the #M 5200.  Jamestown Distributors has list of the many caulk and adhesives.  Again depending on your application you maybe able to use a ceramic potting compound.
http://www.nusil.com/index.aspx
http://www.dymax.com/products/electronic/potting_materials/index.php?gclid=CMSDjZH_16cCFYrs7QodUiUq9Q
http://www.jamestowndistributors.com/userportal/siteMap.do?action=map2&catId=32
http://www.cotronics.com/vo/cotr/cm_potting.htm
