PROKON Software
PROKON Software
PROKON Software
Hi
does somebody knows the PROKON software?
Can I get somewhere in Interent some more infos about it like some tutorials and so on
Tom
RE: PROKON Software
Hi Ussuri
I know thewebside but there are no tutorials or nice exaple exercises sad
Tom
RE: PROKON Software
You can get a demo version from them. Each module includes an example.
RE: PROKON Software
I use Prokon quite a lot and its an easy program to use; so if you need any advice I am willing to help.
RE: PROKON Software
to cve60069:
serious? wwaaooww this sounds good. Thanks I will definately come back to you.
Why are you using PROKON? Are you from southern Africa as well?
pity that they don´t have any books or tutorials or scripts
tom
RE: PROKON Software
I use for structural analysis and I am in the UK.  I use only the 3D frame analysis.
RE: PROKON Software
BauTomTom
You are the first person I have spoken to that uses PROKON. I note that you wish to delve into the scripting language.  I have written several small scripts that worked well and I am planning to write some more small programs.  If you wish to share ideas when you write your scripts we may produce something that works better.  I think we will have to learn the scripts by example and the help files though.
