Orienting a twisted part in Drawings
I have a complex part that I broke up in to several pieces, did a "Save Bodies" and made it in to an assembly for detailing properly in my drawings.
However, when doing "Save Bodies" the part shows up with a common origin to the assembly, and it is all disoriented.
I have attached one of these parts as an example.
I want to be able to get views that are "Normal To" a face, but I also want the lines to be vertical/horizontal.
Is there a way to rotate the part slightly (in the drawing view) without modifying the part itself? (ie. no "Move Part")
Devon Murray, EIT [Mechanical]
Solidworks 2011 SP 2.0
RE: Orienting a twisted part in Drawings
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
MadMango's suggestion would be simpler and (semi)permanent.
the computer screen. use alt or control plus the arrow keys to move part around square to screen as you want.
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
I found one burried on another page:
In the part/assm, select the face you want to be normal
Ctrl+Click the face you want to be the new Top
Then do "Normal To"
After that, setting the views was just another step.
I needed the parts properly oriented so my ISOs would turn out. I guess the title was misleading; I needed to orient more than just the drawing.
There is no right or wrong way ... use whatever works best for you.
