color of sketch lines when cursor is placed over (also test question
Im sure this is a simple fix, but I have looked everywhere so I give up. In sketch mode, when I go to select a line, (for dimensioning or other)the color of the line does not change when I place the cursor over it to make sure I am selecting the correct line. The color has always changed, but it just suddenly stopped. Can someone please throw me a hint?
Also,(in drawings) is there a way to turn off note grouping? When I am trying to place a note near another note or text, it automaticly groups the 2 notes together into a single note.
thanks
thanks
RE: color of sketch lines when cursor is placed over (also test question
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
If it is, go to System Options > Colors and make sure "Dynamic Highlight" and "Sketch, Under Defined" are different.
If what gopack13 said doesn't fix it, try updating your display drivers.
Devon Murray, EIT [Mechanical]
Solidworks 2011 SP 2.0
thanks
MM
