Laminate Join Trouble
Hi!
I´m working with different laminates in the same body in NX 7.5.
I have tried to couple them by "Manual Coupling Constrain" at common regions.
(Do I need to do this? -The model comes from different sweeps in the same design)
The simulation solver apparently runs fine, however when trying to view results, there is an error "Result File is in wrong format", and according to the warning message it's due to "Result collector"
I attach the simulation model before applying the solver
