More Help with Dimension Settings in Standards
Does anyone know which Standard dimension setting(s) will change the length of the overruns/dimension line that's circled in the attached image (below)?
Thanks in advance!
Thanks in advance!
Tim Flater
Senior Designer
RE: More Help with Dimension Settings in Standards
How to control the distance of a diameter or radius symbol from the dimension value?
TIA!
Tim Flater
Senior Designer
I did have a go at setting the dimensions 'prefix' as 'R ' (or similar with diameter symbol) but Catia seems to ignore the spaces in this case.
Do let us know if you find a way to 'set' this although I fail to see when I might feel the need to use it..!
Rishi Mandyam
Automotive Design Engineer
Catia V5 R12 - latest
Chelmsford, UK
