Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This site is truly a marvel. Without a doubt the most comprehensive, friendly and just plain useful resource of its kind..."
Geography
SanderB (Structural)
17 Mar 11 7:29
Hi all,
I'm exploring the steel construction manual 13th edition. But I'm unable to find how I should calculate the rotational stiffness of a connection. Please enlighten me.
JoshPlum (Structural)
17 Mar 11 10:09
Are you referring to a "partially restrained" moment connection?
I'm not aware of any standard guides that have this. I've always told people to look up the test results data (moment rotation curve) and use that as the basis of their connection stiffness approximation.
For fully restrained moment connections you can assume that the beams are rigidly connected to the columns.
17 Mar 11 10:54
Well in Eurocode (EN1993-1-8 chapter 6.3) there is a formula to calculate the rotational stiffness of a connection. They also give an upper value for a connection to be nominally pinned and a lower value for a connection to be rigid.
Now I have found those boundaries in AISC specification for struct steel buildings (Ks >= 20EI/L fully restrained, Ks <= 2EI/L simple). But I can't seem to find a way to calculate Ks, which is the secant stiffness of a connection.
I need to calculate the rotational stiffness for moment connections in order to use them in my global analysis. In fact, what I'm trying to do is theorically predict the moment rotation curve you would get from tests, without actually having to perform these tests.
wannabeSE (Civil/Environmental)
18 Mar 11 0:08
If you are looking for information on non-linear moment rotation curves, you might try the following:
FEMA 356 Prestandard and Commentary for Seismic Rehabilitation of Existing Buildings
UFC 4 23 03 Design of Buildings to Resist Progressive Collapse
ASCE 41-06 Seismic Rehabilitation of Existing Buildings
18 Mar 11 12:17
I agree with wannabeEIT (what kind of a name is that?!).  Those Push-Over and Progressive collapse documents have a good amount of information about moment rotation curves or such for connections.  So, they're probably a good place to start. Unless someone else replies back with a better reference.
ishvaaag (Structural)
14 Apr 11 10:27
One reference that even gives old DOS software to the purpose is
Stability Design of Semi-Rigid Frames
Chen, Goto, Liew
Wiley Interscience
kikflip (Structural)
20 Apr 11 23:51
This isn't referenced in AISC anywhere but I have always treated a connection which able to transfer the minimum of the design action and/or 30% of the member flexural capacity as being a rigid connection for the analysis.
Close Box
Join Eng-Tips® Today!
Join Us             Close
