Typical crankshaft throw radius?
I have a 1995 Nissan Quest with a V6.
Is there anywhere I can find the dimension of the
crankshaft throw?
If not does anyone know the typical radius of a
6 cyclinder crankshaft throw?
Thanks in advance.
crankshaft throw?
Thanks in advance.
RE: Typical crankshaft throw radius?
When you say "crankshaft throw" you mean 1/2 stroke, right?
Carpoint says that your stroke is 3.14 inches, so your crank throw would be 1.57 inches (39.88 mm).
http://carpoint.msn.com/vip/engines.aspx?modelid=2191&src=vip
You might want to double check that figure elsewhere; carpoint is often wrong.
Thanks so much for the pointer.
That is exactly the info I needed.
Pete.
Cheers
Greg Locock
