Power plant synchronization to transmission system
I understand that its standard to opearate a transmission system within 5% of a rated voltage. Can power plant be synched to transmission system at any voltage within 5% of rated as well, or should it be synched at rated voltage?
RE: Power plant synchronization to transmission system
David Castor
www.cvoes.com
May you grow up to be righteous, may you grow up to be true...
http://www.basler.com/html/dwntech.htm
You will probably have to register to download.
David Castor
www.cvoes.com
for the construction of cylindrical-rotor and salient-pole
synchronous generators, respectively. They specify,
"Generators shall be designed to be fit for service without
inspection or repair after synchronizing that is within the
limits listed..." [1] [2]. The limits for both types of generators
are:
• Angle ±10 degrees.
• Voltage 0 to +5 percent.
• Slip ±0.067 Hz.
IEEE Standard 67, which also discusses synchronizing
requirements, specifically says that the standard does not
apply to the prime mover [3]. The author is unaware of any
standards that apply to the design of the prime mover, so the
generator limits are typically the ones used to design a
synchronizing system. However, in practice, wider limits are
often applied because the prime mover control is not fine
enough to reliably achieve a 0.067 Hz slip.
................H
extracted from
Fundamentals and Advancements in Generator Synchronizing Systems
