Printing to PDF troubles
On drawings that have multiple pages, I can print all sheets to the printer or plotter just fine. All sheets print. When I print to a PDF (CutePDF writer), it will print sheet one to a file...I save the file..then it prompts to print the remaining sheets (sheet 2-x) which I save to a different file name (which usually by default is the file name-sheet 1). How can I change it to where it prints to a PDF the same as it prints to the actual printer or plotter? I want one file with all sheets in PDF...not one file with sheet 1 and another file with sheet 2-x. Thanks.
RE: Printing to PDF troubles
Just do 'Save as' -> and select PDF as the file type.
This should save your drawing directly out as a pdf. It allows you to select the sheets to be included (by default it will save all of them into a multi-page pdf).
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Matt Lorono, CSWP
Lorono's SolidWorks Resources & SolidWorks Legion
Follow me on Twitter
It worked as it should by unchecking the "set each drawing sheet individually" box. Wonder how to set this to be unchecked by default?
Eric
