1080 Steel Fine Pearlite
I am looking for a Fine Pearlite stucture after a piece of rail is thermite welded.  The rail steel is essentially a 1080 Carbon Steel.  Specifically the composition is:
Weight Percentage, %
Carbon, C
 0.72 - 0.84
 Manganese, Mn
 0.70 – 1.25
Silicon, Si
 0.10 – 1.00
 Phosphorus, P
 0.02 Max.
 Sulphur, S
 0.02 Max.
Copper, Cu
 0.40 Max.
 Chromium, Cr
 0.20 – 0.40
 Nickel, Ni
 0.15 Max.
 Molybdenum, Mo
 0.05 Max.
 Vanadium, V
 0.01 Max.
Aluminium, Al
 0.01 Max.
Based on a CCT Diagram for 1080 steel it should be cooled from Eutectoid temp of 727°C to 25°C no quicker than 2 minutes and no longer than 166 minutes.  Does this make sense.  See attached.
RE: 1080 Steel Fine Pearlite
Yes, that would be my interpretation of the diagram, but you may want to do some experimenting and lab work for verification.  As compared to spec-grade 1080, the chemistry you have listed has boosted levels of Si, Mn, and Cr among others that could affect 'hardenability' and bias the resulting microstructure, probably toward the P+M zone.
What I don't get is the 40°C/s and the 5°C/s it doesn't match with the time scale on the x-axis?
The time scale on the x-axis is just seconds (s) of time and your comparing a cooling rate of deg C/s to seconds.
Yes I understand that, I'm not that slow.
I don't understand a) how is the cooling rate constant?
b)If we take a constant cooling rate of 40C/s, it means that from 730C to 0C, it would take 18.3 seconds.  That doesn't match the x-scale which says 10^2.
The cooling rates associated with the three curves (5, 40, 140 C/s) are incorrect with respect to the x-axis.  The author and editor(s) of this textbook did not catch the error.  If you look at other CCT diagrams you can see that a cooling rate of 40 C/s is associated with the 10 second order of magnitude, not 102.
Ok so I should cool the steel from the critical temp no quicker than 10 seconds and no longer than 166 minutes?
