*vwrite or *mwrite ?
Hello
Is it possible to fill a table/matrix from columns that I got from the *vget command? I want to write a .txt-file with the *vwrite command but it can only handle up to 19 parameters.
I have a composite laminate with 20 layers and the *vwrite command will only write out the first 19 layers. I want the layer number in the columns and node results in the rows.
So, i was thinking maybe I could fill an table or something with all my results from the *vget command and then use *vwrite,table instead.
Or maybe I need to use the *mwrite command instead?
Anyone who has any idea?
