Coliled coil
Coliled coil
Hi!
I'm trying to figure out a way to make a "coiled coil" in Pro/E, I try some method, but it was not working. I think the Curve by Equation is good, but I don't know this parametric equations.
Please Help!
THX
Please Help!
THX
RE: Coliled coil
RE: Coliled coil
A coil is a helix, so like dgallup said, use a helical sweep. You can do it with a curve by equation too, and the equation should be simple if you know you pitch and diameter.
RE: Coliled coil
If you want something like that you can use a Helical sweep to make a surface coil and use it's edge as a path for a Variable Section Sweep.
The VSS can consist of a single line with a relation to make it curve around whatever path you use.
Michael
RE: Coliled coil
RE: Coliled coil
RE: Coliled coil
RE: Coliled coil
But I thinked, anybody know a easier method for this coil.
RE: Coliled coil
RE: Coliled coil
RE: Coliled coil
Thanks lot everybody!
