MAPDL into Workbench?
Hi!
I've modeled a structure using the Mechanical APDL application. Now i have to perform a strain-life fatigue analysis, which i think is only avalaible within the workbench environment. My cuestion is, is it possible to import the model and the results from the apdl application to the workbench environment?
Thank you very much!
RE: MAPDL into Workbench?
I'm pretty sure that you can set fatigue events with the FE command in MAPDL. There's a list of fatigue commands (FE, FP, FL, FS, etc.) in the Ansys command reference that may be useful to you.
