Basic Command in Abaqus
Hello everybody,
I am  a newbie in Abaqus. I want to program a model in pyton script. When i run my Pyton  script (with abaqus) i want to start the analyse of the job. For that i make the job with the follow command:
mdb.Job(atTime=None, contactPrint=OFF, description=', echoPrint=OFF,
    explicitPrecision=SINGLE, getMemoryFromAnalysis=True, historyPrint=OFF,
    memory=50, memoryUnits=PERCENTAGE, model=myModel, modelPrint=OFF,
    multiprocessingMode=DEFAULT, name=nameJob, nodalOutputPrecision=SINGLE,
    numCpus=1, numDomains=1, parallelizationMethodExplicit=DOMAIN, queue=None,
    scratch=', type=ANALYSIS, userSubroutine='isotropic2F.for', waitHours=0, waitMinutes=0)
After that i want to begin the analyse thus i want to use the command submit(...)
I found in a tutorial http://abaqus.civil.uwa.edu.au:2080/v6.6/books/ker/default.htm
 for using this command,  i must use
import job (before)
and if i understand i must use the command mdb.jobs[submit(name job)].
I don't arrive to use this command .
Could you help me to understand how is the syntax.
Thank you
