Target Points in drawing
I would like the place a target point in my drawing view and be able to set the dimension (.060).
Looking at the help files, target points are not associative to model geometry, so how would I do something like this?
Also, when dimensioning the targets, the dimensions are off. I'm thinking this is because of the scale factor for the particular view?
Thanks in advance,
Chris
Thanks in advance,
Chris
RE: Target Points in drawing
To me it doesn't look like it's associated to anything on the model.
Go to...
Insert -> Curve/Points -> Point...
...and using the Offset option, create a Point located relative to what you wish to reference at the location where you with the Target Point to be. Then using the Target Point Symbol function select this point as it's 'Location'. Now just Hide the original Point and you should be good to go.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Another question.
After I get the point in there and place the target on it I put the dimensions in and they are off by the scale factor (supposed to be .060 but ends up being .240 because of a scale factor 4:1 in the view). Is there a scaling option I'm missing?
vertical dimensions are corret, horizontal dimensions are not.
some dimensions are off, some aren't.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
I right click the view, select expand member view, and my sketch tools toolbar becomes grayed out.
But if you insist, go ahead and create your Point using the 'Active Sketch View' approach, THEN Expand your view, place the Target Point Symbol, un-Expand the view and create your dimension.
In reality, it's NOT the Point that needs to be explicitly created inside the non-1:1 scale view, but rather the Target Point Symbol that needs to be located there to get the expected dimension.
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
John R. Baker, P.E.
Industry Sector
Cypress, CA
