Eliminating linked features
I have a few files that have linked features that I need to completely break the link. A linked body is fairly easy, you can remove the parameters of the linked body and it turns into a 'body' feature (dumb solid, which is fine for my purposes) and the child features update OK. However, if the linked feature is a datum feature, removing parameters is not possible. Is there a faster way to completely break that link or will they have to be replaced and relinked to child features by hand?
RE: Eliminating linked features
Note that the big advantage of 'breaking' the WAVE links using the 'edit' command is that while the links are truly broken, the feature is still such that if at some later date you wished to reestablish those links or assign them to a new parent, the features already knows how to do this by simply using 'edit' command once more.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
John R. Baker, P.E.
Industry Sector
Cypress, CA
The secondary problem I'm running into is very generic names were used for these development files and TC is erroring out on duplicate part names.
