DXF File Conversation
I'm not an expert ACAD user, nor a beginner, and need some help with a DXF file. I received a DXF file from my surveyor that consists of point coordinates only. I've converted to a DWG and connected the dots to generate an as-built. I would now like to convert the DXF file to some type of TXT file (or equal) so that I can submit the as-built drawing and raw data to the Project RE. What is the easiest way to do this?
Brent
Brent
RE: DXF File Conversation
A simple way if that isn't possible is to use the "list" command then select all points. Copy and paste the results from AutoCAD's text window to a text file.
B+W Engineering and Design
Los Angeles Civil and Structural Engineering
http://bwengr.com
Good question, brandonbw, I agree. Turns out the surveyor is not the brightest bulb. One of those "do it myself because its easier" situations.
Thanks.
