Carburetion of Propane in Petrol engine
I am looking for info regarding the best way to send low pressure vaporized propane into a gasoline carb.  Has anybody here made a clever part to connect the vaporizer to the venturi?
RE: Carburetion of Propane in Petrol engine
Kits I've seen for my generator are a regulator and a tube that sticks into the venturi. I think some of the kits replace the carb completely if you never plan on using gasoline again.
Check Google for small engine conversion kits.  There are three basic conversion methods, a drilled in spud (the method you describe), an add on venturi, and a total replacement.  I have several running with the add on venturi.
Franz
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
