How to view .MAX files
Hi all
I've been sent some files in the .max format (3ds max), is there any way of opening these without having 3ds max software installed on my PC?
Is there a viewer that's available somewhere, something like edrawings.
Just for info; I have Solidworks & UGNX on my PC.
RE: How to view .MAX files
Thanks madmango, I'll give it a try.
I use a program called Designer.  It's a 3D design software by a company called Threedify and can open around 40 different file formats from different 3D design software such as studio max and even autocad.  The benifit, I found, was the ability to open, then modify the rendering.  The company to which I'm refering has another program as well that will allow you to then export your mark-ups ect... into microsoft office.  This allows for easier sharing.  As a designer, I never know what file format I'm getting, so this is a pretty good little program. They also have some demos on You Tube.  www.threedify.com/fr/lightweight-3d
