Setting Text Node Justification in MS VBA
I'm trying to place a text node in VBA and i want to set it's justification to CenterCenter.  TextNodeElement.Justification is readonly...
CODE
Dim txt As TextNodeElement
txt.Justification = MsdTextJustification.msdTextJustificationCenterCenter
so i cant set it that way...
Any ideas?
RE: Setting Text Node Justification in MS VBA
There are a few ways to accomplish this.
1. Set the active text node justification prior to creating the text node
ActiveSettings.TextStyle.NodeJustification = MsdTextJustification.msdTextJustificationCenterCenter
2. After you place the text node modify the justification on each element in the text node
Dim ee as ElementEnumerator
set ee = txt.GetSubElements
Do While ee.MoveNext
   ee.Current.AsTextElement.TextStyle.Justification = MsdTextJustification.msdTextJustificationCenterCenter
Loop
Option 1 worked.
Thanks for the help.
