Chamfer vs fillet
Chamfer vs fillet
How do you choose between chamfering or filleting a sharp corner. Are there any factors to consider besides flipping a coin?
RE: Chamfer vs fillet
Chamfers generally are more forgiving when fitting mating parts.
Beyond those concerns, atmax is right.
General consensus around my place is that chamfer is a bit cheaper.
Of course, senior management, industrial designers etc ten to prefer fillets.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I don't have first hand experience, just reiterating something I read.
Sometimes chamfers are easier to produce other times rads are. For example a milled pocket with chamfers is a real no no.
The same applies to wire erosion, laser cutting, water jet etc you will always get a rad so with a chamfer you still get two rads on that chamfer on internal corners.
Software For Metalworking
http://closetolerancesoftware.com
