Corrosion of 301 stainless
Does anyone have comparative data for corrosion resistance of 301 vs. 304 stainless steel? Our use is medical. Parts are exposed to steam sterilization at 132 C. The 304 we are using now is fine for this application but we need the strength we get with 301 1/2-hard.
RE: Corrosion of 301 stainless
Can you try a sample?
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Plymouth Tube
