Problem with Outputting to DXF
I am trying to output dxf's to our 3D cad software (Solid Edge ST3) from Altium Winter 09.
The issue arises when the traces are outputted as lines with width. I need outlines of the traces to create drawings from (ceramic substrate) for the supplier.
Does anyone know if this is possible? or where the options are to select?
Thanks.
Thanks.
RE: Problem with Outputting to DXF
Can you use wireframe mode?
Dan - Owner
http://www.Hi-TecDesigns.com
