PED test temperature
I have a question about the test temperature according the PED. I need the test temperature for calculation the test pressure (1,25 x Ps x Fa/Fts). Does somebody know how i can calculate the test temperature and where i can find these calculations (in the en 13345 norm?)
Thank you in advance
RE: PED test temperature
The test temperature is simply the vessel wall temperature during the test (the water temperature in a hydrotest). It is normally the room temperature.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
