Create DXF draw elements
I have done this before but I cannot recall how to do it now. I am creating a DXF of the draw space elements. The trouble is that the section views do not show any part of the model when I do this. How do I get the DXF export to look like the CATIA drafting sheet? Thanks. I am using CATIA 4.2.2 on an AIX box.
BU
RE: Create DXF draw elements
Hi again,
I do not think this is hard but I cannot remember it. Let me explain it better. I thought that I would select SPC > DR command to have the space elements appear in the dxf export but this does not work. Is there a command and a way to select the entities globally to have them contained in the draw space and then be able to dxf export them?
