Moving a CO2 laser, issues?
Hello all: We need to move a old but operating 2KW co2 laser, fixed optics, moving table type, while we do have some documentation, its in spanish. Im curious about removing the delivery tube and its optics, can we break it at the 90 and put it on a pallet, should all the optics, 2 - 45s and a 90; be removed, how fragile are they? Does the resonator unit require special packing or a sling cradle on the trailer. OC? Any concerns or tips you would care to share on this issue would be most appreciated. I realize it takes time, effort, and thought to respond on these forums and wish I could offer more than just a thanks.
RE: Moving a CO2 laser, issues?
Not knowing your exact setup, I can only give you some basic help. I would rec removing any glass discharge tubes. Duct tape over any turning mirrors (the apertures, not the optic itself) in the resonator to keep debris from getting on the optics. I really wouldn't remove the optics as this would more than likely cause the need for an optical alignment upon restart. Some resonators have "shipping brackets" that hold them firmly in place during movement. Drain all coolant lines to avoid freezing. Not required here in Phoenix AZ. :) HS&E may require removal of any vacuum pump oil or oil from the HV power supllies. You may need brackets for the blower unit as well.
It would be prudent to contact the mfr for this machines specific requirements, after all, these things are $$$ to fix.
Hope this helps,
Scott
I really am a good egg, I'm just a little scrambled!
Dan - Owner
http://www.Hi-TecDesigns.com
Dan, I was wondering, in another thread you mentioned wanting to build a 100W DPSS fiber laser. May I inquire why? ( Perhaps I should just visit your website and that will answer my question )
Scott
Dan - Owner
