Fence post
Fence post
We are installing chain link fence with privacy slot which act as windscreen at front of outside generator. Basically it stops snow drift in the winter season. This fence always built with schedule 40 pipes. But engineer made comments to switch to HSS 102 X6.4- ASTM A500 Grade C. Supplier told me that we never did this before and all fitting are only compatible with Schedule pipe.
Is there any comparison between Sch40/80 pipe to HSS ASTM500Grade C section?
And is there any design reference material to design handrails and fence post?
Thanks for your time.
RE: Fence post
As for design standards, in the United States I would typically use the IBC, ASCE 7, and AISC standards. But I assume that you aren't located here because you referred to the HSS dimensions in millimeters.
RE: Fence post
NAAMM Manuals
RE: Fence post
A500 is Fy=46 ksi yield
A35 is Fy=35 ksi yield
There are A500 sizes in AISC Steel Manual which jive with 'standard' pipe sizes
How about decreasing the Post Spacing to get a smaller size to work?
