acceptable values for Bus Ductor Test
Hi
Can any body tell me what are the acceptable code values for contact resistance (Bus Ductor Test) to bus sections, bus bars ..etc
Thank you
Thank you
RE: acceptable values for Bus Ductor Test
You need to consult the manufacturer's recommendations on acceptable test results. That said, a max contact resistance of 10 micro-ohms is often quoted for large bolted joints.
