Solver Non-Negative Variables - VBA command
I am writing an Excel 2010 VBA code that calls Solver and I need to tell Solver to uncheck the "Make Unconstrained Variables Non-Negative" box. The default is "True", ie. the box is checked. When I uncheck the box and run my code, and ask Solver to return the state of the box (SolverGet(TypeNum:=20)), it keeps coming back as "True". I can't find any function in the MSDN Library that will allow me to change it to "false". It seems you can change every other variable but this one. Any thoughts, as I have little experience in VBA.
The "Make Unconstrained Variables Non-Negative" feature is new in Excel 2007.
RE: Solver Non-Negative Variables - VBA command
Why don't you use macro recorder to record what changes in the solver command?  In 2007, the recorder recorded:
    SolverOptions MaxTime:=100, Iterations:=100, Precision:=0.000001, AssumeLinear _
        :=False, StepThru:=False, Estimates:=1, Derivatives:=1, SearchOption:=1, _
        IntTolerance:=5, Scaling:=False, Convergence:=0.0001, AssumeNonNeg:=True
TTFN
Chinese prisoner wins Nobel Peace Prize
I didn't see the "AssumeNonNeg" function in MSDN until you listed it.  It is there.  My Bad!  Thanks IRstuff.
