Hopefully simple sheetmetal question
I've created a sheetmetal part - basically a rectangle - then added 90deg. edge flanges to three sides of the rectangle. I then added edge flanges to these (folded same direction) and then to these, edges flanges folded in the opposite direction. All is well; the part flattens beautifully.
I added it into my assembly and edited it in context to get a couple of cut-outs in desired places (two circular ones in flange 1 and one in flange 3). When I went back into the part, the sheetmetal wouldn't flatten.
I'm not quite sure why, as I'm sure I've done similar things before! What have I done wrong?
RE: Hopefully simple sheetmetal question
- - -Updraft
http://www.yourfilelink.com/get.php?fid=625531
*Crosses fingers*
I know it's a simple part, but I'd like to know the right way to do things from the off. Appreciate the guidance!
The Flatten tool should then work correctly.
FYI, you could have created the flanges in one feature using the Mitre Flange tool.
Thanks for the tip as well. Will try that in future.
