Three Face Blend
Three Face Blend
I'm trying to create a three face blend on the attached part as the image attached. following the PDF, but I'm not able to obtain the result as the image.
Can someone can give me the solution ?
Thank you...
Using NX 7.0.1.7 MP3 and TC8.1
RE: Three Face Blend
I do not believe if it possible to do it this way. But I can be wrong...
This is new in NX7.5.
Thank you...
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
so there is no solution using the face blend in NX7 ?
This shape is a cut in the plastic part, so it's very difficulty use the trim body or similar workaround.
Thank you...
John R. Baker, P.E.
Industry Sector
Cypress, CA
Hope this is of use.
Frank Swinkels
Thank you...
Sorry about the conversion to inch units. I imported a parasolid rather than opening it directly.
Frank Swinkels
Frank Swinkels
Frank Swinkels
